1. mgemensky
    mgemensky New Member
    Jul 10, 2005
    I have a well pump that is 2 years old. It repeatively goes of and on very quickly, when the pressure goes down to 20 lbs (where it is set) I have to hold it closed to make it fill back up to pressure. This is the 2nd new pressure switch I've installed in 2 days. I've check the lines and they are clear and there is no leaks in the bladder. Could the pump its self be bad? Or are there any switches I could adjust to make it work correctly? Right not when we use water I have to stand by the pump to make it pump back up to pressure.
  2. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    Have you checked the tank's pressure with the tank empty? it should be set at approx 2 psi below the pumps cut-in setting.
  4. mgemensky
    Jul 10, 2005
    Thanks, when My husband gets home I'll have him try that.
  5. mgemensky
    Jul 10, 2005
    Ok, the psi is set at 2 below the full psi so that is not the problem, is there anything else we could try?
  6. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    As Hube suggested, the precharge in the tank should be set 2 psi less than pump cutin pressure, not 2 psi less than full pressure.
    Since you said the pump comes on at 20 psi, the tank should be set at 18 psi. It needs to be completely drained when you set this pressure.
    Ron
Similar Threads: Pump issues
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Tuesday at 7:09 AM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Nov 18, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Sub Well Pump Control Box Issues.... May 26, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Pump pressure issues May 21, 2013
Pumps and Tanks Well Forum & Blog. Water is life. sears shallow well jet pump mo. 390.25021 pressure switch issues?? Jul 22, 2010
