The two bleeders are designed to drain the pipe from the check valve at the tank down to the bleeder. When the pump comes back on this pipe full of air gets shot into the tank, which is how it maintains the air charge needed. There is probably another check valve in the well above the upper bleeder. This check valve should keep the pressure tank from losing pressure when no water is being used. But if that check valve is not working, you can add another in that line going into the tank.
And the Michigan law about the extra check valve is for bladder tank type systems. Air over water tank system must have the check valve above ground, or able the bleeders to work properly. The above ground check valve on an air charge system doesn't cause a negative pressure in the underground line, because the bleeders let it drain out.
