Pulling Pitless Adapter
Discussion in 'Pumps and Tanks Well Forum & Blog' started by bonfis, Apr 13, 2009.
  1. bonfis
    bonfis New Member
    Apr 13, 2009
    I recently uncapped my well casing to evaluate the possibility of pulling a dead submersible pump. About 5' feet down the casing I can see a plate that is the same diameter as the casing with 2 semi-circular slots and a bolt in the center. The wire to the pump passes through 1 of the slots in the plate. There is no sign of any safety cable or rope or anything else for that matter above the plate. This is not what I expected to see based on the research I've done on pulling pumps. There is no sign of a pitless adapter. I'm wondering if the bolt needs to be removed and the threaded hole used for pulling the pitless adapter? Does anyone out there have any experience with this situation? BTW my house is about 40 years old, the well is about 100' and the water is used only for the lawn.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I wouldn't remove anything until I knew what would happen when I did. There are several manufacturers of pitless adapters and they are all different. Some are held in place with simply gravity, others have jamming devices that push an oring in place against a seat.
    You could deep six the whole string if you loosen the wrong thing.
    bob...
  4. Gary Slusser
    Retired
    Post a picture.
    I take it you can't see the water line right?
  5. bonfis
    bonfis New Member
    Apr 13, 2009
    Right. All that's visible is the plate described in the original post and the power wires that pass through a slot in that plate.
Similar Threads: Pulling Pitless
Pumps and Tanks Well Forum & Blog well pulling sand Jul 13, 2016
Pumps and Tanks Well Forum & Blog Advise for pulling a pump in Honduras Nov 28, 2015
Pumps and Tanks Well Forum & Blog Help pulling well pump Jun 20, 2013
Pumps and Tanks Well Forum & Blog Pulling 100 ft. deep 2 inch packer well May 7, 2013
Pumps and Tanks Well Forum & Blog Pulling a submersible - not sure if this is right May 19, 2012
