pt valve leaking on hot water tank
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nap, Mar 30, 2008.
  1. nap
    nap New Member
    Jan 27, 2008
    British Columbia
    The pressure/temp valve on my hotwater tank is leaking so I have replaced it along with my vacuum relief. the valve continues to leak so I had put a pressure gauge on my outdoor hose bib and found it had spiked to 150psi so i changed out my prv my house is 50 plus years old and figured that had to be the problem. Check the pail under my P/T valve and it has water in it again. What is causing it to open.
    PT
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    have you addressed thermal expansion in any way? And wow..150psi house pressure!
  4. nap
    nap New Member
    Jan 27, 2008
    British Columbia
    Yup 150psi
    No I havent looked at thermal expansion not sure why that would be a problem now . The one thing I did not check was to see where my gas valve pressure was at. It is a new john wood tank with the thermal link that opens if the tank exceeds 200 F and the valve needs to be replaced if that happens
    PT
  5. jadnashua
    If you have an expansion tank, it is probably shot. If you don't have one, you need one. A PRV produces a closed system, a waterlogged expansion tank means there's no place for the heated water to expand, increasing the pressure and dumping enough to relieve it out the T&P valve. Depending on your water quality, pressure, and maintenance, they can last anywhere from a few years to a decade or more, but will and do fail.
Similar Threads: valve leaking
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Monday at 12:06 PM
Plumbing Forum, Professional & DIY Advice Main valve leaking Jun 10, 2016
Plumbing Forum, Professional & DIY Advice American Standard ceramic disc cartridge leaking at valve May 20, 2016
Plumbing Forum, Professional & DIY Advice Repair leaking tub valve integral (screw driver) stop? Jan 18, 2016
Plumbing Forum, Professional & DIY Advice Main Water Valve Leaking Jul 18, 2015
