PRV outlet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by charlie m, Jun 25, 2007.
  1. charlie m
    charlie m New Member
    Jun 23, 2007
    Hi,
    I have a PRV outlet pipe running from beneath my combi-boiler through the wall to the outside of my building. I am wondering if it is okay to redirect it into the overflow outlet beneath the heater, which runs into the general waste pipe of the building. Cheers
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Probably not legal....
    Check with your local plunbing codes to make sure....
  4. jadnashua
    That's probably a Temperature and Pressure safety valve, not a pressure reduction valve. The problem with them is that when it blows, the water can be hot enough to flash into steam...very dangerous stuff. If it is leaking, it probably should be replaced - they don't last forever. If it is weeping, double check the state of the expansion tank...it could be shot causing the valve to leak when the boiler kicks in. It is generally safer to have them discharge outside. Check with the local codes.
Similar Threads: outlet
Plumbing Forum, Professional & DIY Advice Pungent smell from the electrical outlet/kitchen Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Kennard rear outlet dual flush Jul 24, 2016
Plumbing Forum, Professional & DIY Advice Rough in for toilet with two outlets???? May 15, 2016
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice Icemaker outlet box tight squeeze Jan 6, 2016
