Proximity of Return Air Grill to Damper
Discussion in 'HVAC Heating & Cooling' started by kailor, Mar 9, 2011.
  1. kailor
    kailor Member
    Dec 2, 2010
    Huntsville, Alabama
    It won't be long until I'm ready to have my self-contained AC condenser unit installed. I will install the return air grill in the floor and the damper underneath the main trunk.
    1. The manual says to install the damper forward of center of the home.
    2. I will minimize the supply and return duct lines as much as possible.
    3. I will keep the damper at least 3 feet from a floor register.
    4. I'll not install the return air grill in a high-traffic area.
    My question is this:
    How far from/close to should the damper be installed from the return air grill that will be located in the floor?
  2. kailor
    kailor Member
    Dec 2, 2010
    Huntsville, Alabama
    Answer: It does not matter
    What does matter is where you place the return air.
Similar Threads: Proximity Return
HVAC Heating & Cooling Pressure locked return manifold Sep 24, 2016
HVAC Heating & Cooling Shifting Supply & Return Main Trunks over 3' Apr 10, 2015
HVAC Heating & Cooling Enlarging/replacing main cold air return vent Apr 6, 2015
HVAC Heating & Cooling Chilly Finished Basement Needs Cold Return? Mar 26, 2014
HVAC Heating & Cooling Can forced air supply duct be run through panned returns? Oct 28, 2013
