ProFlo 32 gallon well pressure tank won't take an air charge
ukiltmybrutha
Virginia
I am troubleshooting a bigger issue but that thread is being moderated. I hope that this thread will slip through as nothing is wrong with it.
I am trying to charge up the subject pressure tank with my Milwaukee M18 tire pump and cannot get it to 2 psi below the pressure switch low pressure number of 40 which would be 38 PSI.
I don't know how the inside of this pressure tank works want to know if this definitively means that my pressure tank is bad.
Thanks.
No water...no fun!
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Pressure tanks are made to fail, it is just a matter of when. Sounds like the diaphragm is broken and letting out the air charge. Tank diaphragms break from going up and down over and over as the pump cycles on and off. You can just replace the tank, or you can use a Cycle Stop Valve to solve the cycling problem.
ukiltmybrutha
Virginia
Can I install a CSV with the leaking tank? Thanks. Also, do I have to buy the same brand of pressure tank to avoid having to rework the plumbing?
