Price Pfister diverter valve
Discussion in 'Shower & Bathtub Forum & Blog' started by macguy59, Mar 26, 2013.
  1. macguy59
    macguy59 New Member
    Mar 26, 2013
    Illinois
    Had a problem since day one of moving into the condo. I have a 3 handle setup in our shower. The center handle is the diverter that when turned redirects the water flow to the shower head. It does but water is also still pouring out of the faucet. It's overwhelming the drain to the point that the tub gradually fills with water while showering (making for a grimy looking tub). I pulled the valve and had it identified as a Price Pfister (PF stamped on the valve assembly). I opted to replace the entire assembly rather than just the washers. The new valve looks identical to the one I'm replacing. It screwed in fine and the handle went on like it should but no joy. Still have the same problem even with the new valve. What else do I need to look at/for ?
  2. jimbo
    jimbo Plumber
    Assuming you put the new stem in correctly ( we can talk about that later) then we can mention 2 possibilities:\
    1) Water pressure in the house way too high. Easily checked at a washing machine hose connection, with a simple guage available at hardware store.
    2) The tub filling up could indicate an not-related drain clog. But if the pressure is too high, it might be overwhelming the drain.
    Check your pressure, if OK....take out the diverter stem, inspect, and post photos.
  4. macguy59
    macguy59 New Member
    Mar 26, 2013
    Illinois
    Thank you for the quick reply. I suspected a drain problem first so I had Roto Rooter over here to snake it. They couldn't find a clog. I didn't replace just the stem. I replaced the entire valve assembly so I'm not sure what I could have done incorrectly but I will pull it back out and take a picture. If it's a case of water pressure being too high . . . I should be able to reduce it at the main shut off correct ?
  5. macguy59
    macguy59 New Member
    Mar 26, 2013
    Illinois
    Well in the process of taking the new valve assembly out to take a picture of it, I immediately saw what the problem was. One too many of the large flat white washers which was preventing the valve stem from seating all the way. I couldn't spell plumber yesterday but today . . . lol
  6. hj
    Because the diverter is a "double seated" valve the distance it goes in is critical. Therefore,either an extra washer, or a missing one, will cause the symptoms you had.
Similar Threads: Price Pfister
Shower & Bathtub Forum & Blog Price Pfister 3 handle tub faucet leak Feb 20, 2017
Shower & Bathtub Forum & Blog Price Pfister Shower Issue Nov 28, 2016
Shower & Bathtub Forum & Blog Price Pfister Avante, Help with removing trim plate Nov 14, 2016
Shower & Bathtub Forum & Blog Price Pfister OX8, Anyone recognize this faucet? Oct 24, 2016
Shower & Bathtub Forum & Blog Price Pfister 0X8 shower valve integrated shutoffs Apr 3, 2016
