pressurize RO reservoir water? need help
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Kyle Dudley, Jul 16, 2012.
  1. Kyle Dudley
    Kyle Dudley New Member
    Jul 16, 2012
    Michigan
    im trying to pressurize the water from my reservoir so i use in my grow room. right now im pumping the water into 5 gallon jugs and carrying them upto my room,
    my idea is to use a sump pump(float switch disconnected) to a smal 10-20 gal pressure tank controlled by a pressure switch, and them from there to my room that will have multiple faucets/spickets
    theoretically it would be a small scale well system but instead of the pump in a well it will be in a 35Gal reservoir
    will this work?? will a sump pump be strong enough to work with the setup i described?and how powerful should the pump be(horsepower wise?)?
  2. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    I don't think plants want to live off of r/o water.. i think they may need some minerals in the water. not sure though because I don't grow pot, er, um,... plants and flowers and such. just a thought though. if you really want to use r/o water, why not just run a longer tube up to your room? the r/o faucet would not be able to make a lot of pressure before it shut off and went down the drain as waste water. the r/o system should be able to pump about 25 feet of 1/4" tube, so just run a line to where you want it and then use a shutoff at that point. easy peasy.
Similar Threads: pressurize reservoir
Pumps and Tanks Well Forum & Blog. Water is life. WellMate WM-HP-110 - how to depressurize the system Sep 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How to get water in to bladderless pressurized irrigation tank? Jun 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. non pressurized tank(?) & winterizing ?s Sep 29, 2015
Pumps and Tanks Well Forum & Blog. Water is life. adding additional 50-100 gallons of pressurized storage to shallow well system Aug 1, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Bottling Pressurized Methane from Well Water Jun 21, 2013
