Pressure Tank Bladder?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Doozy8, Jul 18, 2011.
  1. Doozy8
    Doozy8 New Member
    May 30, 2011
    NJ
    Hello all. how do you know if your pressure tank bladder is shot? My pressure switch is tick tocking back and forth from 40 - 60 or so and I have noticed that the water pressure is the house is hit or miss lately.
    Any advice?
    Thank you
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Does the pressure hold when there is no water being used or does the pump still cycle? If it cycles continuously, there is a leak somewhere.
    One way to check on the bladder is to calculate how much drawdown that size of tank should have and then measure the drawdown. If you come up way short, the bladder is suspect.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Drain the water from the tank and measure the air pressure at the schrader valve. The sticky at the top of the pump & tanks forum describes the process quite nicely.
  5. Doozy8
    Doozy8 New Member
    May 30, 2011
    NJ
    I am sorry for not seeing your responses sooner, but thank you both for your advice. I will check the sticky in the forum. My neighbor had the same problem and had his pressure tank replaced about 2 months ago.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Poke the air valve, if water comes out the bladder is shot
  7. hj
    Or shut off the pump and drain all the water from the system, then measure the air pressure. If the bladder is shot it will be ZERO. If the tank is upright, it will act like a conventional storage tank, meaning it could be shot and still not run water out of the air valve, at least not until all the air is absorbed by the water.
  8. djg
    djg New Member
    Jul 23, 2011
    Indiana
    i have a question about the color of my well water, i had bought my first home a year ago and it passed all inspections,the home was built in 1958, has new water heater, and the bladder tank looks fairley new,when i run the cold water to fill a bucket up,it comes out clear,and stays clear for a little while, then it gradually turns a rust color and stains my dogs stainless steele water dish,but when i had used water softner pellets it doesnt seem so bad,what causes this color change?and is it harmful for my dog to drink?and when her water sits for a few hours, she refuses to drink it but will drink fresh water when offered,any answers to this is appreciated, as i know little about well water, and where could i get my water tested at?
  9. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    While that would certainly be true, the test is not conclusive. Some bladder tanks have the air valve at the top so a partially waterlogged tank would still have air at the top.
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Another test is to add air while the draincock is open. If the air escapes through the draincock, the bladder is leaking.
  11. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Your problem is iron and has nothing to do with a bladder so you should start a separate thread.
  12. Doozy8
    Doozy8 New Member
    May 30, 2011
    NJ
    Nothing comes out of the valve, not even air. My neighbor had the same problem as me and had the tank replaced. I am going to attempt to replace the tank today. I've already replaced the pressure switch and pressure relief valve 2 months ago. This is only 1 pipe (1" or 1 1/4"). I hope it's pretty straight forward.
    Anyone have tips, advice or suggestions for a newbie at this stuff? I don't have a plumbing background, but like to try these things myself.
    Thank you
  13. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    If you have to replace the tank I suggest that you research the Pside-Kick http://www.cyclestopvalves.com/products.html The Pside-Kick comes with a small tank (all that you need today), a constant pressure valve and all the components that you need. It will cost you less than a new large tank and you'll love the constant pressure.
Similar Threads: Pressure Tank
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Jan 25, 2017
