Pressure switch problem??
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Marster, May 18, 2006.
  1. Marster
    Marster New Member
    May 18, 2006
    Hi there.
    I have a Goulds 1hp swallow well pump. My holding tank is from Lowes ( dont know brand) Anyhow, my pressure was set at 18 in the tank and pressure switch was set at 20/40. Everything was fine then all of a sudden when the pressure switch was called to kick on, it hestitated for about 10 seconds. This problem got worse very quickly. Wrnt from 10 seconds to about 30 and now I have no water. I can force the points ( amature) together to get water but that's not right.
    Any advice would be greatly appreciated. Going to drain pressure tank today and check pressure. Pressure tank is fairly new. App 2 yrs old. It's not water logged but if the pressure isnt right could it casue this problem?
    I have a new pressure switch, but not sure how to install and what all i need to drain in order to install. Please help!!! or advise on anything I may be over looking.
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    Make sure the line from the pump head to the pressure switch isn't plugged up. Goulds pumps seem to do this pretty often.
    Turn the pump off, drain the system, and remove the 1/4" line. Take a piece of wire and run it through the fitting on the pump head. This should clear any debris out of the way. Make sure the hose isn't plugged up, too.
    You'll lose prime when you do this, so be sure to fill the pump and suction line up before you run the pump.
    Ron
  4. Marster
    Marster New Member
    May 18, 2006
    Pumpman
    Thanks for the advice. You were correct. The line was open but where the line screwed into the pump head was clogged. I cleaned this out best I could, put it back together and works like a charm! :)
    I didnt have to prime.
    Thanks again!!
Similar Threads: Pressure switch
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch question Yesterday at 8:33 AM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch not providing true short Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Is a pressure switch needed for this gravity fed system? Dec 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch nipple length?? Nov 11, 2016
