jonnyz
I have a well pump that is giving me problems. The pump will not run. The first thing I checked was breaker to see if it had tripped. It had not. I then checked the pressure switch. The contacts are closed and do not appear to be burnt. Both the supply side and the motor side are reading 240 volts. I do not know what the pump is since I did not own the house when it was installed. Here is the info on the control box: Franklin Electric, Model: 2801050103, HP 1/2, VOLT 230 Hertz 60, Max Amp 5.9, Automatic Thermal Motor Protection.
The pressure switch is Square D, Class 9013 Ser B, FSG, On 30 psi, Off 50 psi
Any suggestions on what I should check next?
