SeriousDIYer
I am having fits. I just installed a new well saver 52 gallon pressure tank, 3/4hp water ace shallow well jet pump, pro plumber 40/60 pressure switch. All new plumbing, new 10/2 wire new 30 amp breaker. My tank is set at 38psi, verified using tire pressure guage. When I turn on the pump, it works fine until it builds pressure to 58psi, then the pressure switch starts to click, click, click until I turn the pump breaker off. What in the world do I need to do. One adjustment screw on my presure switch. Do I need to make an adjustment? The pump came with a 30/50 pressure switch that did the same thing. I though cheap or bad switch, changed the switch and same problem. Any suggestions? I was told that I may need to install a pulse reducer at the bottom of the pressure switch.
