Pressure Switch and Sand Problem!
Garry
Aiken, SC
I have a 80 ft. well. It has been drawing a small amount of very fine sand all along. Now it is pulling sand a silt fairly heavy to the point of the water being discolored. It holds pressure as long as the water isn't on but when I turn on water, the pressure switch constantly clicks on and off the entire time. It burned out the 40/60 pressure switch. I replaced it with a 30/50 and it still constantly clicks the points on and off. Help!:confused:
Speedbump
Active Member
Riverview, Fl.
Sorry to be the bearer of bad news, you need a new well. Preferably drilled by someone who can drill a sand free well.
bob...
Garry
Aiken, SC
Is there no other way? I have had this operational for almost 4 years. Could it be a broken casing? Thank you for the help Bob!
Speedbump
Active Member
Riverview, Fl.
Sorry, I've been out of town.
I don't know how you could improve on what you have. The sand is just there and it's almost impossible to make it stop.
bob...
Raucina
All sand aside, this just sounds like a bad pressure tank. Pumps dont cycle on and off from no water, but from a waterlogged tank. Stop thinking about a well until you check out your tank and add some air.
No water, you will get an ON but not an OFF. On- Off should mean bad tank.
