Pressure Relief Valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by terrell44, Apr 14, 2005.
  1. terrell44
    terrell44 New Member
    Apr 14, 2005
    Replaced pressure relief valve on 40g gas water heater about a year ago because of leackage from relief valve pipe. This did resolve the problem, but after only 1 year the problem is back. Any suggestions??
  2. breplum
    breplum Member
    Oct 2, 2004
    Plumbing and heating contractor
    San Francisco Bay Area
    Did you check house pressure. If it is high, that can be the cause. Next, is there a check vavle or pressure reducing valve without bypass? We find that even with bypass, there can be high pressure developing...so an expansion tank, properly installed and charged usually solves the problem.
  4. hj
    valve
    More of the valves fail by not opening rather than leaking spontaneously. So you were probably just lucky that replacing it fixed the leaking, but you probably did not solve why it leaked. Either the heater temperature is too high, in which case you would usually get a flood rather than a drip, or the pressure is getting too high.
Similar Threads: Pressure Relief
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure relief valve -- in a jam Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Water Heater Pressure/Temperature Relief Line Jun 23, 2016
Plumbing Forum, Professional & DIY Advice What is this fitting? → Pressure relief valve. → Weird pressure problems. → High water pressure! Jun 4, 2016
Plumbing Forum, Professional & DIY Advice California (la) Plumbers. Service Entrance Pressure Relief? Apr 25, 2016
