Glaswegian
- Messages
- 6
- Reaction score
- 0
- Points
- 0
I have a deep well about 150ft yesterday noticed that pressure was bad. Checked the expansion tank when system had 0 pressure and pressure was ok at 28lbs. Changed the pressure switch out and still have the problem. Pressure won't rise above 15lbs. Water runs ok at that pressure except there isn't much because of the pressure. Is there an obvious problem that I am not seeing? Pump sounds like its running and like I said if I leave water running it doesn't stop. Would I be right in thinking that mabye some of the seals or impellers in the pump have gone and thats why I can't get pressure or is there something else I should check. Well is 13 years old
