Pressure jumps fast between 35 to 50 PSI
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dbduran, Jun 19, 2007.
  1. dbduran
    dbduran New Member
    Jun 19, 2007
    With water running from the faucet, my well pump cuts-in around 28 psi. When it slowly reaches around 37 psi it rapidly jumps to 50 psi and then the pumps cuts-out. Then the pressure drops rapidly down to around 37 psi. From 37 psi down to 28 the pressure drops normal. What is causing the rapid pressure increase and decrease between 37 and 50 psi?
    I drained the water in system until 0 psi on gage. I checked tank pressure with an air gage. I could not add more air above 21 psi using a bicycle pump.
    Why could'nt I add more air to the tank?
  2. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    You may have a tank leak on the air side of the bladder. It doesn't take much leak to be large enough to leak out at fast as you can pump with a bicycle pump when you get to 21 psi.
    After you pump it up, immediately check the air pressure and then watch it for a few minutes. If you lose air in a short time, then the tank is leaking.
    I chased a problem like that for a while and discovered the air leak at the welded fitting near the outlet on the air side of the bladder. It was not possible to see it when the tank was installed.
    You might be able to check it with a little water in the tank. When there is water in the tank the water pressure gauge will read the air pressure. If the pressure drops with no water usage and pump off, that is another indication of an air leak in the tank.
    Bob NH
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Most likely the bladder tank needs to be replaced.
  5. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    You didn't describe the tank. Could it be a WX-203 Well-X-Trol?
    You are topping out the bladder. That's why it jumps from one pressure to another. The bag has hit the top of it's travel. Some 203's had a dome in them to prevent tearing the bladder from overextension. When the bladder reached the dome, the tank could take no more water so the pressure rises immediately to shut off.
    bob...
Similar Threads: Pressure jumps
Pumps and Tanks Well Forum & Blog. Water is life. Shared well, water pressure jumps up and down May 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Sunday at 7:40 AM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well head pressure relief valve Feb 6, 2017
