Pressure Gauge read 100+
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Steven Palmisano, Mar 31, 2008.
  1. Steven Palmisano
    Steven Palmisano New Member
    Jan 21, 2007
    Florida
    The pressure gauge is reading a 100+ psi (maximum range), it normally reads 50 psi. Everything seems to be running fine. Pressure is the same in the house as usual, pump is not running constantly, all seems normal except the gauge reading.
    Should I be worried, will the tank explode?
    Do you think it is the gauge?
    Is it hard to change a gauge?
    Is this something I could do myself being a novice plumber at best?
    Appreciate the feedback..
    Steve
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Use your tire gauge on the tank air valve to verify the pressure. You probably let it freeze and the gauge is reading 50 pounds too high.
Similar Threads: Pressure Gauge
Pumps and Tanks Well Forum & Blog. Water is life. New Pressure Gauge Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. No Water - Pressure Gauge At 70 Apr 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure good gauge but drops Jul 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. I got a pressure gauge. Long story. Not having a problem. Jun 6, 2015
