Pressure Gauge Going Back and Forth
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Doozy8, Jul 7, 2011.
  1. Doozy8
    Doozy8 New Member
    May 30, 2011
    NJ
    I woke up this morning to less pressure than we normally have. I went downstairs to check the pump and the pressure gauge was at about 30psi, but my irrigation system is running, not sure if that has anything to do with it. I shut the breaker for the well pump and when I turned it back on, the pressure gauge would tick-tock between 40psi and about 60-70psi and go back to 40, then to 60-70 without the well pump turning on at all.
    Is this normal or something I need to be concerned about and need to fix before a major problem occurs (like I had on Memorial Day....http://www.terrylove.com/forums/showthread.php?42014-Non-stop-water-coming-from-release-valve!!!!!&highlight= Everything has been fine since.
    Please let me know if this is of concern or normal function.
    Thanks!!!
Similar Threads: Pressure Gauge
Pumps and Tanks Well Forum & Blog. Water is life. New Pressure Gauge Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. No Water - Pressure Gauge At 70 Apr 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure good gauge but drops Jul 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. I got a pressure gauge. Long story. Not having a problem. Jun 6, 2015
