pressure balanced vs thermostatic valves (1/2 inch vs 3/4 inch)
You want the bench sloped just like a floor at about 1/4" per foot so water doesn't pool on it. It depends on the type of waterproofing system you use, but moisture hitting the bench/wall junction will try to penetrate, so it needs a path to the drain so it doesn't accumulate or penetrate.
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
I never really thought about sloping the bench but I guess it would be a good idea. Thanks a lot John.
How far up the wall do you think the liner needs to go? and just on the wall where the bench is?
That is a very nice sloped ceiling on that site you posted. I don't have very much room in the attic but may have just enough to be able to come up with a sloped design somehow. I will have to crawl up there and have a look.
Like Jim mentions 1/4" per foot is nice.
The linear should come up the wall at least 4-6" to get a dececent lap with the poly.
Isn't that a slick design. I love the fact that from outside it still looks contemporary and inside offers up the slope. Very well designed shower!!!
To bad the showcase shows an poor waterproofing effort. Some times too much of something is no good.
JW
Shawn_T
Vancouver, BC
I just heard back from the green e board people and they say the following: "GreenEboard can be used in a steam room when properly installed with a product such as Hydroban."
Have you heard or experienced differently, or do you just always use cement board and have not tried GreenEboard? I have already bought the green e board so I think I am going to use it along with the vapor barrier and the hydroban, unless I hear differently.
Thanks again for your feedback.
JohnfrWhipple
North Vancouver, BC
Let me call them and ask a few questions. I'll get back to you as soon as I can.
I sent out a message to the Brass at Green EBoard. Hopefully I hear back today or tomorrow.
JW
Shawn_T
Vancouver, BC
Hi John. I will be curious what the brass at GreenEboard will have to say. Thanks for contacting them.
I think I am starting to change my mind to using Nobleseal TS instead of going the hydroban route. If I use Nobleseal TS, it does the vapor barrier job and I don't have to use another vapor barrier, correct? What other products need to be used if I use Nobleseal TS, Noblesealant 150? anything else? Where is the best place to buy Nobleseal TS?
Thanks a lot for all your help.
JohnfrWhipple
North Vancouver, BC
I spoke with Derek just now and we are waiting to hear back from Joe on Tuesday - hold tight.
Noble Seal TS is hard to come by. I think Golden Flooring will be stocking it soon. I order in my stock through the online store.
JW
Shawn_T
Vancouver, BC
Thanks John. I will hold tight to hear back. I am in no extreme rush because I'm hoping to get started with the plumbing in a couple of weeks.
I looked online and it appears that you can get Nobleseal TS from an american company toughtool.com which is distributed by a seattle company called masterwholesale.com. I will maybe order from this site and have it shipped to the border. It is only $6.77 and then $30 to ship to the border. I have used a cross-border shipping company called ship happens quite a few times and they are great.
This same site also has Noblesealant 150 for less money ($18.28) so I will probably order that also. Are there any other products that I would need to go along with the Nobleseal TS and the Noblesealant 150?
In your experiences, are there one or two different rain shower heads that stand out above the rest? I have heard good things about the Moen Velocity S6320.
JohnfrWhipple
North Vancouver, BC
I have not had enough showers to choose one over another but I can tell you the showers with lower flow rates do not make my clients happy.
This rain head was not making the grade and then the client requested the shower restrictor removed. My plumber did and the net result is a wonderful full stream of water.
JW
Shawn_T
Vancouver, BC
Hi John - If I finish off my steam shower by using Noble Seal TS, would I just continue from where the liner stops on the top of the bench or would I have to bring it right down to the floor over top of the liner? Are there any other products that I would need to go along with the Nobleseal TS and the Noblesealant 150?
Also, did you happen to hear back from Derek or Joe about the GreenEboard?
Thanks a lot for your help.
JohnfrWhipple
North Vancouver, BC
Sorry Shawn.
I haven't had a chance to try Joe back. With regards to using Noble and a traditional liner I might suggest you email Eric @ Noble and check with the head tech himself.
I have always build my steamers with a full topical water/vapour barrier approach so I have no first hand experience with a hybrid method.
Eric Edelmayer <eric@noblecompany.com> If he dosen't know then no one will.
Send Eric a link to this thread so he can see your pictures.
For what it's worth I might scrap the liner and go all Noble Seal TS. This will save you the trouble of wire lathing and mudding the bench. If that doesn't sounding appealing then email Michael Getzlaf <canadian.mosaic@shaw.ca> from Laticrete and he can help walk you through a Laticrete install.
We are starting up a new steam project on Davie and Beach in a couple weeks. Full Thermasol Steam shower kit with sound and chromotherapy lighting!!! Just got the call today.
"The Steam is Dream!" :)
JW
JohnfrWhipple
North Vancouver, BC
I managed to track Joe down yesterday and he was kind enough to free up some time for me and all my questions.
You'll love this. Joe has had a sheet of Green EBoard in his truck for almost two years. Rain, Snow, Car Washes ....
He has asked his technical crew to do a further study on the subject before confirming to me one way or another. That is what I like to hear from my manufactures - not a sales pitch but let us double and triple check the facts.
As for your project right now I think you need to follow the TTMAC recommendations for a steam shower build. The specs from Laticrete on a Hydro ban shower are great ones to use as a resource.
Or rip out the liner in now and go full Noble Seal TS and follow Noble Companies spec sheet.
I would do the later. We are not fond of using any backer board cementious or otherwise in a shower with no topical waterproofing measures.
Shawn_T
Vancouver, BC
Thanks for asking Joe all the questions John. My GreenEboard has been sitting outside (not in the rain) for about 4 months and looks the same as it did the day I bought it. I like the fact that Joe has had his through rain, snow and car washes.
I think I will go with your suggestion and order some Noble Seal TS instead of using the Hydro Ban. Some of the Noble Seal instructions recommend to install the Noble Seal TS behind the backer board instead of over top (although you can install it over top, except for the ceiling). Most of the examples I see are installed over top. Would you think I should install it over top of my GreenEboard or behind? It seems like over top would be the much easier way.
My shower dimensions are 3ft x 5ft with 8ft ceiling. This includes a bench. I am going to order 33 feet of Noble Seal TS. From your experience, do you think I will need more than three tubes of Noble Sealant 150?
Do you think I will need more than 2 gallons of Nobleseal EXT?
Do you think I should buy the preformed inside corners, or just form the corners myself?
Can you think of anything else I will need that I haven't mentioned? I am going to place the order right away because I am going down to Washington in a couple of weeks and will pick everything up then.
Thanks again. Your feedback has been very helpful.
JohnfrWhipple
North Vancouver, BC
Shawn I do not think Noble EXT is approved for steam showers. Check this with Eric. I would be using a top of the line modified thin set and not EXT product from Noble.
As for installing the Noble Seal TS on top or behind the Green EBoard on the ceiling I have always installed it on top and not behind. We use modified thin set and give it a good length of time to cure before tiling. I think Noble wants you to install it behind the backer board - I'm not sure exactly why. To cover all your bases you might consider doing all the walls in Green EBoard and then covering with Noble Seal TS (including the ceiling). Then use Super Panel for the ceiling with proper cement board screws.
I have always build my steamers with the vapour barrier on top of the backer boards. Perhaps I have always built them wrong? I just looked up the steamer specs this morning in my TCNA guidelines and there is no mention of the waterproofing going behind the backer board. Email Eric and ask this question Eric Edelmayer <eric@noblecompany.com>.
I do not like the idea of a backer board taking on water or steam anywhere my shower construction.
When installing Noble Seal TS on the ceiling make sure you have an extra pair of hands. My last steamer in China Town I tried troweling the Noble Seal TS first with thin set and then installing it on the ceiling. This worked great but it is easier have a second pair of hands. Installing the Noble Seal TS to the framing would obviously be the easiest route.
Installing Kerdi, Noble Seal TS or any sheet membrane is much harder than applying a liquid membrane. Consider your installation experience and perhaps try installing it all in smaller pieces with more seams. This will cost you a little extra in Noble Sealant 150 but will most likely make the install easier.
The inside and outside corners are worth the expense. Make sure the outside corners go in first. The inside ones it does not matter.
JW
Shawn_T
Vancouver, BC
Thanks John. You are correct that Noble EXT is not approved for steam showers and I do like the idea of using super panel for the ceiling.
JohnfrWhipple
North Vancouver, BC
It might be a liability issue perhaps with Noble. Imagine if you set a 4'x2' stone up there that would be a lot of weight supported by just the fleece on the Noble.
We have done a number of jobs with Noble Seal TS and 1'x2' tiles and have had no issues.
Make sure you use proper screws for the cement board.
As crazy as it seems but we often pre-drill the board with the self tapping wafer head screws and then swap them out for the cement board screws. I find the wafer heads pull the board tight and the pre-drill causes less stress on the cement board.
With the Green EBoard #8 Stainless screws are golden we go through about a 1/2 pound per 3'x5' sheet or roughly $6.00 per board. On a typical steamer I would grab a 2.5 pound bag of Stainless Screws. Your attaching to wood studs right? With condo work I like the fine thread drywall screws. But that is a thread in of itself boarding in Condos...
We bang the green eboard up with a few ring shank galvanized drywall nails to hold it tight to the wall and then screw it off.
Shawn if your around my neck of the woods you can always call me and check out these materials. I always have loads of stock around. I live North Van between Westview and Cap.
JW
Shawn_T
Vancouver, BC
Thanks for the tips about the screws. I guess it is best to use lots of them and make sure the board is not moving anywhere. I am screwing into wood studs and am going to use mostly 18" porcelain tile. I am going to pick up my nobleseal ts and sealant next week but I can't start anything yet because one of my pulumbing valves is on backorder. Can't wait to start seeing some progress.
