Power Pipe Really Work?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Greatwhitewing, May 13, 2011.
  1. Greatwhitewing
    Greatwhitewing New Member
    Apr 19, 2011
    MA, United Staes
    Looking at a 60"-72" long 2" power pipe hooked up to my shower only in a wall on the first floor between the shower on second floor and basement where the boiler is.
    Does the thing really work as advertised? http://www.renewability.com/general/residential.html
    We have 4-5 people showering every day. Installing a Viessmann oil VR1-22 and Superstor 45 gallon indirect soon.
    Or is there better ways to save oil? Also insulating all the hot pipes I can access.
    Posted here because this is the busiest forum.
    http://www.renewability.com/uploads/documents/en/backgrounder.pdf
    [​IMG]
  2. hj
    Your shower water will be 120 degrees or less and that will only be while the water is running. I cannot imagine a "40% savings" given the limited amount of heat transfer area in the actual device, and the inequality of the velocities of the pressurized water and the gravity drain..
Similar Threads: Power Pipe
Plumbing Forum, Professional & DIY Advice Frozen pipe prevention for Mobile home after power outage... insolvable problem? Feb 7, 2014
Plumbing Forum, Professional & DIY Advice Power Pipe Installed + ABS drain pipe question Dec 19, 2013
Plumbing Forum, Professional & DIY Advice Shorter Power Pipe? Apr 26, 2011
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Buderus GB142 - no power Oct 10, 2016
