Power disconnect panel for spa...
Discussion in 'Electrical Forum discussion & Blog' started by MJ32V, Feb 26, 2008.
  1. MJ32V
    MJ32V New Member
    Feb 18, 2008
    NY
    NEC min height req'mts for spa power disconnect?
    Hi All,
    What's the height requirement for a power disconnect panel for a spa? Outdoor location 50' from side of residential 1 family home. Disconnect will be mounted on 4x4 press. treated post just shy of 10' from closest point of spa. 220V / 50A GFCI.
    MJ
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    6' 7" max.....but don't mount it that high.
  4. MJ32V
    MJ32V New Member
    Feb 18, 2008
    NY
    6' 7" max... ok. What's the minimum height above ground?
    While we're on the subject, what's the recommended height?
    Thanks,
    MJ
  5. jadnashua
    High enough so it doesn't sit below normal snow depth or standing water. You don't want to have to crawl on the ground to remove and replace. My unprofessional opinion...
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I agree, put it so you work on it like a gentleman...
  7. MJ32V
    MJ32V New Member
    Feb 18, 2008
    NY
    jadnashua -
    There's never more than 3' of snow in the area the disconnect is located. Let's say that I placed panel 4' off ground, then later find out that code has a 5' minimum height, then I have to re-work things (arghh!). So to avoid issues later, I need to know what the code minimum height requirements are.
    MJ
  8. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    There is no minimum height just a maximum of 6 feet 7 inches to the center of the grip.
  9. MJ32V
    MJ32V New Member
    Feb 18, 2008
    NY
    Great. Thanks....
    MJ
  10. jfkopper
    jfkopper New Member
    Feb 14, 2007
    If your spa is ever used by kids, I would suggest placing the disconnect low enough to be easily used by the youngest---if Mom gets her hair caught in the suction port, help might need to come from the smallest of spa mates.
    For a scary (and tragic, but relevant) story see
    http://www.poolspanews.com/2003/102/102entrapment.html
    /Kop
Similar Threads: Power disconnect
Electrical Forum discussion & Blog how do i disconnect power on a split buss? Jan 5, 2012
Electrical Forum discussion & Blog Disconnecting power Sep 26, 2007
Electrical Forum discussion & Blog Power feed problems Feb 20, 2017
Electrical Forum discussion & Blog New Outlets= Erratic Dimming Power Jan 10, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
