Possible Defective Pressure Control Switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by one900steve, Mar 26, 2009.
  1. one900steve
    one900steve New Member
    Mar 23, 2009
    New pump system for my semi-artesian well and has been working fine until we disconnected and reinstalled the tank under new base cabinet.
    After reconnecting (leaving the originally set 30-50 psi range) the tank now cuts-in at 30 psi as usual but cuts-out at around 33 psi, giving an apparent short cycle. I checked the air pressure and it is set to 28 psi (measured with the tank drained).
    I figured the cut-in to cut-off range got reset some how. I adjusted the nut by tightening it by 10 turns or more and it did not change. None of the controls were tampered with during the setup and protective cover remained on the whole time.
    Any suggestions, first time well and pump owner?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If the pressure switch you have does not have 2 adjustment nuts, then you have no way to adjust the differential between on and off. Pressure switches are cheap. Get a new one with 2 adjustment screws.
  4. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    Have you checked the accuracy of the gage? With all the adjusting you did to the switch, it should have changed something. You should either get a new switch or try and put the setting back the way it was, and get a new gage.
    Make sure the pipe or tube going to the pressure switch is clear of any mineral deposits or any other type of blockage.
    Just a thought.
    Travis
  5. one900steve
    Mar 23, 2009
    Hi, sorry for the late response.
    Thanks for the response, it turns out that it was just the gauge as Waterwelldude suggested. I replaced the gauge with a Winters, liquid filled gauge last night and reset the control switch nut back to where it was as best I could. When I started the pump up it cut-out at exactly 50 psi and now cuts in at exactly 30 psi.
    Unfortunately, I never tested my line before we covered up the new floor and now when it gets to 50 psi and cuts out, it slowly loses pressure. I now have a slow leak somewhere on the feed line it seems.
Similar Threads: Possible Defective
Pumps and Tanks Well Forum & Blog. Water is life. Possible to replace bladderless tank with bladder-type tank? Jul 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Possible Replacement of Pressure tank Needed Nov 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well head cover impossible to get off Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Best pump for hard water also, please review our setup & suggest other possible improvements Oct 22, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Septic Tank-possible problem. Sep 13, 2013
