Pop-Up Drain Assembly question
Discussion in 'Shower & Bathtub Forum & Blog' started by khayes, Oct 5, 2011.
  1. khayes
    khayes Member
    Oct 25, 2005
    Alpharetta, GA.
    I know this is pretty basic. I have 2 new vanities with undermount sinks. The sinks are Kohler with the drain holes in the middle of the basins. The problem I have is the pop-up linkage is not long enough to reach the pull-up rod in the faucet. How do you handle this? All the older sinks I've seen had the drain hole located toward the back of the sink, but now that they are in the middle, the rods are too short.
    One more question (maybe should be a new topic?)...on a Moen shower valve, is it possible to change the finish from brass to oil rubbed bronze with a trim kit or will I have to install a whole new valve?
    Thanks for any help.
  2. jadnashua
    If you know the model number of the Moen valve, then you can determine if there are still other trims available for it. You may be able to view the website and determine what model you have (if you don't know or can't find the documentation).
    As to the pop-up, I've seen clamp on extensions to that lever but don't know if they are available as a standalone part. One of the pros might, or a good internet search.
  4. hj
    The easiest way to extend the rod is with a "rod coupling" which has set screws to anchor it, (NOT the threaded kind), and a bolt or piece of plain rod the same size long enough to reach the mechanism. Depending on the model Moen valve you have, you probably need Moentrol trim, which is available in many newer finishes.
  5. khayes
    khayes Member
    Oct 25, 2005
    Alpharetta, GA.
    Thanks Jim - I went out and bought another pop up assembly and used the bar, with a few bends, to jump over to the down rod. It works fine.
    Ken
Similar Threads: Pop-Up Drain
Shower & Bathtub Forum & Blog Looking for a 2" toe touch (pop-up) drain without overflow for dual-shower / bath Jul 16, 2012
Shower & Bathtub Forum & Blog Pop-up stopper for a 2" drain Ell Sep 6, 2010
Shower & Bathtub Forum & Blog Pop-up style bathtub convert to a trip lever drain Nov 17, 2005
Shower & Bathtub Forum & Blog Help for Pop-Up Drain for Jacuzzi Nov 24, 2004
Shower & Bathtub Forum & Blog GERBER POP-UP LINKAGE ASSEMBLY Jan 30, 2017
