Polybutylene to PVC
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nedriv, Dec 21, 2006.
  1. nedriv
    nedriv New Member
    Dec 21, 2006
    Hello all, I'm a new member and have a question.
    My current water main from my well to the house is Polybutylene. It's been in place for over 20 years. I am building a small granny-flat apartment and want to splice into the Polybutylene and extend water to the new building using PVC. This is for cold water only.
    My question is: Are there fittings I can use to splice into Polybutylene and use PVC for the new building?
    Thanks for any help you can provide.
    Ed V
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You should not be using PVC to run water into the house. You should be using copper if you have the pocket book or polly pipe.
  4. nedriv
    nedriv New Member
    Dec 21, 2006
    Cass, Thanks for the quick reply. I am not familiar with the code, haven't done the research yet. Is there some code reason to not use PVC or is it a personal preference? If code allowed PVC, what would the reasons be to not use it?
    I can't use copper due to a slightly acidic PH from my well.
    When you say I should use polly, you mean Polybutylene right? If yes, that's great! I didn't think I would be allowed to use Polybutylene due to all the problems people had in prior years. I just thought PVC would be better than Polybutylene. I would prefer to use Polybutylene, if it is allowed by code.
    By the way, I live in California, El Dorado county.
    Thanks again,
    Ed
  5. jimbo
    jimbo Plumber
    "poly" in underground service these days refers to polyethylene. I think PB is still approved, but don't know if they even still make it. It is not found commonly, but the polyethylene is.
    Copper is widely preferred, but in your case with low ph, it would probably not be appropriate. Also, these days, the cost of copper is enough to make you consider almost anything!
  6. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Check out Qest fittings to make the tee or transition. Pex is what I'd highly recommend if you have the capability. In my area almost everyone who is not running copper runs all water lines in CPVC. PEX is still new and not many have adapted to using it but it is highly recommended.
  7. Gary Slusser
    Retired
    On a well water system, PE is the best choice. PB was never used for well work. PE is the norm except in the west where they still use galvanized and in the south, PVC rules (nop frost). PE has been used for many decades. Copper would be the least desirable for a number of reasons but mostly because you can't hang a pump on one piece of it and get it out very easily; in 1" or 1.25". CPVC is a very poor choice and if anything other than PE rolled pipe, PVC is best. Pex isn't a good choice and costs more than PE.
  8. Phil H2
    Phil H2 New Member
    Sep 12, 2006
    Tujunga, CA
    Check with the local building department. California has not been a plastic pipe friendly state (may change in upcoming codes). Since you have acidic water, the local juristiction probably has some plastic freindly exceptions.
  9. hj
    pipe
    PVC is the most common exterior plastic pipe used here. But, if this it the pipe from the well to the storage tank it may not be usable for your purposes unless you install a storage tank. And even then, it will only get water from the pump when the main building's system turns the pump on.
Similar Threads: Polybutylene
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Best fitting for connecting to polybutylene plumbing Mar 9, 2015
Plumbing Forum, Professional & DIY Advice Polybutylene advice and budget Jan 15, 2014
Plumbing Forum, Professional & DIY Advice Soldering Near PEX, Polybutylene Nov 18, 2013
Plumbing Forum, Professional & DIY Advice Need expert help, polybutylene water service? Oct 7, 2013
