Plastic Wall Box
Discussion in 'Electrical Forum discussion & Blog' started by K2, May 27, 2010.
  1. K2
    K2 Member
    Jul 7, 2008
    Some computer junk...
    Delridge Valley
    Hey guys, long time no talk.
    I've got a bathroom wall light fixture that I'm replacing, and when I got it up there it causes the box to come out past the drywall a bit exposing the box...which is undesirable.
    Is there something I can do (besides ripping the drywall off and replacing with a metal box) to help this thing stay in place? Maybe a small clip that holds the plastic box behind the drywall?
    Thanks,
    k2
  2. Ian Gills
    Jul 24, 2007
    USA
    I would try make two pieces of metal-like tabs through which you put the screws that attach the fixture to the box. These can flip up behind the drywall. When you tighten down the fixture, everything will be pulled to the wall.
  4. 6t7gto
    6t7gto DIY Junior Member
    Jan 20, 2010
    Bedford, Ohio
  5. K2
    K2 Member
    Jul 7, 2008
    Delridge Valley
    thanks! those tabs look like they might do it! how do theywork exactly?
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Assuming the box has top and bottom flanges to keep it from falling into the wall, simply slip the long parts of the clamps in beside the box (one on each side) and behind the drywall, then pull the fingers out tight while holding the box back tight against the drywall and bending/wrapping the fingers around the edges of the box and tucking them down tight inside it. At that point, the straps should be holding the box in place with its top and bottom flanges/tabs back tight against the surface of the wall around the hole.
Similar Threads: Plastic Wall
Electrical Forum discussion & Blog NM buried in plastic conduit Jun 28, 2016
Electrical Forum discussion & Blog Grounding after changing to plastic service line Feb 27, 2012
Electrical Forum discussion & Blog running cat6s inside plastic conduit with 120v Feb 19, 2011
Electrical Forum discussion & Blog How to remove plastic strain relief connector? Jan 4, 2011
Electrical Forum discussion & Blog Tabs on plastic electrical box Jul 9, 2009
