TomBrooklyn
- Messages
- 17
- Reaction score
- 0
- Points
- 0
Are Pittsburgh pipe wrenches any good, such as the 24" aluminum one from Harborfreight? http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39606
Hi,master plumber mark said:They are good if you are going to use them only once or twice...But If you are planning on reliyeing on them every day, they willeventually drive you crazy fighting with them trying to get a grip on a pipe and you will throw them a way...
it all depends on wether you are a
weekend warrior or do it for a living
Hi.GrumpyPlumber said:pipe wrenches, Ridgid only.
TomBrooklyn said:Hi.
Is Ridgid really the only company that makes a solid, good quality pipe wrench?
OK. Sounds like Ridgid is the only way to go. I picked up a steel 24" Ridgid on ****. Got it for $29 and the teeth look pretty OK as far I could tell from the picture.CHH said:Yup. Don't even look at anything but Rigid. If you're going with a wimpy aluminum handle then it doesn't matter so much.
TomBrooklyn said:OK. Sounds like Ridgid is the only way to go. I picked up a steel 24" Ridgid on ****. Got it for $29 and the teeth look pretty OK as far I could tell from the picture.
TomBrooklyn said:Are even the aluminum Ridgids not so good?
TomBrooklyn said:I got some 100 year old steam heating pipe risers and takeoffs I want to either remove or relocate. They range from about 1" to one 2 1/2" (I think.) I have a feeling they're not going to come apart easily. I'll probably have to get another pipe wrench as the biggest one I have now besides the 24" is an 18." I figured I'd wait until the 24" got here and see how it felt. I was even wondering if I'd need a 36" for that 2.5" riser.
Should I be staying away from the aluminums altogether?
Sounds like steel is a lot more versitile. And with steel wrenches I will need to spend that much less time in the gym. I'll stick with steel. Cheers.CHH said:If you're doing serious refit work then you'll need some steel for the tough connections.
TomBrooklyn said:Hi CHH,
Thanks for the guidelines on wrench sizes. I got only one connection to remove that's 2" or 2.5" so it sounds like I'm on the borderline with the 24". I got oxy-acetylene handy too so I could heat it up real hot. Will have to see how it goes.
TMB9862 said:Aluminum pipe wrenches are great, much easier on the arms. I very rarely use a steel one and haven't broken and aluminum one yet. Doesn't ridgid offer a lifetime warranty on their wrenches anyway?
I measured the riser and it's 2.25" OD so I guess that's a 2" pipe. I think the main horizontal main is 3". I'm not sure how a plumber would fix that tee if it broke, but I have an arc welder and could weld a piece back in. How would a plumber normally go about replacing a 3x2 tee that broke in the middle of a steam line anyway?GrumpyPlumber said:As for hammering...oooooh dunno if that'd be the best idea if the pipes as old as you say, unless you're prepared to replace what breaks.
I know the new ones at the supply house all have the little sticker saying the housing is warrantied for life. I suppose if it's obvious you put a pipe (or a truck) on it they wouldn't honor it though.CHH said:Back when the aluminum first came out the story we always were told was "no" on the warranty. Of course anyone that knew us wouldn't honor the warranty anyway...there seems to be something about tying a pickup to a 36 that voids the warranty but I don't know what it is...
