Pipe stub for hand held shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rsmith99, Dec 28, 2008.
  1. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    I am installing a new hand held shower. It comes with a small flush chrome fitting that takes the place of the shower extension that normally comes out of the wall and attaches to the shower head.
    Can you tell me how you get the exact length of the pipe needed to attach the flush mount fitting to the brass fitting in the wall?
    Since it can't be seen after it is installed, are there any worries about this connection leaking in the wall?
    Ron
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    All of the hand-held showers that I'm aware of screw directly on to the old shower arm. I don't know why you would need or want to replace the shower arm.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Like this one...
    [​IMG]
    or, this one...
    [​IMG]
  5. Verdeboy
    Jun 12, 2006
    Okay, you got me there. I'm not familiar with those fancy models.
    But you didn't answer his question. ;)
  6. Redwood
    Dec 15, 2007
    Service Plumber
    You can't unless you a re initially installing the dropear 90 in the wall The best you can hope for it to get close. If the 90 is far enough back in the wall you can actually use 2 nipples and a coupling. It is more forgiving.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    There is a specialty tool that can be used to measure the length of the nipple required. It's called a "Tape Measure" Measure from the face of the drop ear ell to the face of the escution and add 1 1/4 "
  8. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    Specialty Tool
    I believe I have one of those "Specialty Tools".
    Would the nipple be made of brass or galvanized? The elbo is brass.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Then all it has to do is measure up to the 1/2" lengths of nipples available. use brass.
  10. Snets
    Snets New Member
    Dec 22, 2008
    California
    Is adding the 1-1/4" standard for all pipe sizes?
    So what you are saying is that a seated pipe fitting is accomplished by threading it in 5/8"?
    Just trying to get clarificatin so I don't screw it up. Unfortunately the drop-ells that come with these hand showers have no trim piece so they are made to go flush against your tile and sealed at the same point.
  11. jadnashua
    Sounds like it may be a Kohler...they are particularly fussy about the exact length nipple. A pipe thread needs to be tightened enough to seal well and not come loose. You can sometimes adjust how deep it will go and get tight by the number of wraps of Teflon tape you use. For extra insurance, it won't hurt to use both the tape and pipe dope. It might be worthwhile to get an internal pipe wrench. You can start the nipple on the crome finish piece and then use it as a wrench to tighten everything together.
  12. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    I have one of those and it came in a box that says "wall union".
    Since the nipple can't be accessed one would have to tighten both the joints at the same time, by turning the fancy outside elbow (wall union). I have to stick a screwdriver into the outlet to get some torque on it to tighten it.
    There is no access to the inside joint, so it's not easy to tell if its weeping or leaking. I like the idea of tape and dope both, just for good measure, on both of the joints.
Similar Threads: Pipe stub
Plumbing Forum, Professional & DIY Advice Product suggestion: Stubout for PEX Repipe into Finished Walls Oct 18, 2016
Plumbing Forum, Professional & DIY Advice Bathroom sink pipe fitting stuck in drain stub out - please help! Aug 31, 2013
Plumbing Forum, Professional & DIY Advice Stubborn kitchen pipe Dec 22, 2011
Plumbing Forum, Professional & DIY Advice Bathsink tailpipe & Wall stub Apr 11, 2010
Plumbing Forum, Professional & DIY Advice Is there any acceptable way to glue a PVC fitting onto a galvanized pipe stub? Feb 6, 2010
