Pipe size between 1.25 and 1.5
Discussion in 'Irrigation / Sprinkler Forum' started by DeeD, Apr 25, 2009.
  1. DeeD
    DeeD New Member
    Apr 24, 2009
    We are doing some repairs and we have thought we had 1" pipe however, we seem to have a pipe that is between 1 1/4" and 1 1/2" - is that possible? Is it possible that it is schedule 80 or something that makes it a tad bigger than 1 1/4"? It is not itself a coupling, but we are scratching our heads here...
  2. jimbo
    jimbo Plumber
    scheule size pipes are all the same OD, and vary by wall thickness and ID.
    Are you measuring OD or ID to evaluate the pipe size??
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    PVC pipe or poly pipe? There are size standards other than IPS, which is what the PVC you'll encounter is manufactured to.
  5. DeeD
    DeeD New Member
    Apr 24, 2009
    Well we haven't actually measured, but the 1" collar/union doesn't fit over it. We have tried a 1.25 reducer and a 1.5 reducer and they don't fit either (too small and too large)
    On other factor -this is the main pipe from the sprinkler shutoff to the valve box.
  6. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Come back with better photographs. Dig out more dirt from around the problem area. There are no shutoff valves that I know of, connecting to PVC pipe, that are not IPS standard.
    If it happens that you are looking at PEX tubing, then that's a whole other story.
  7. hj
    Pvc
    IF the "collar", whatever that is, was too small for a 1" pipe, then BOTH 1 1/4 and 1 1/2 should have been too large. You are doing something wrong, or are giving us bad information. They do not make "in between" pipe sizes so you are measuring them wrong or are trying to use the wrong parts for whatever you are trying to accomplish.
  8. PSLawnService
    PSLawnService New Member
    May 16, 2009
    Lawn Service - Owner
    Minnesota
    Clean off the pipe. There might be some printed info on it.
    Was the system installed commercailly? If it was, the pipe is very possibly black in color or less likely green or blue.
    If the system was a do it yourselfer all bets are off. There is some pipe manufacted for ag aplications that don't match much of anything.
    If possible bring a sample of the pipe to your local hardware store. They should be able to tell you what kind of pipe you have and maybe even give you some tips on how to repair it.
Similar Threads: Pipe size
Irrigation / Sprinkler Forum General advice: do these pipe sizes seem okay? Dec 26, 2013
Irrigation / Sprinkler Forum HELP ME with this pipe size... May 23, 2011
Irrigation / Sprinkler Forum Pipe Size Jul 1, 2009
Irrigation / Sprinkler Forum pipe size for underground system? Aug 14, 2008
Irrigation / Sprinkler Forum Changing pipe size Jun 29, 2008
