Pipe cover?
Ingeborgdot
Kansas
I am not even sure what the name of this would be but here it goes. Coming out of the wall going to the toilet is the copper fitting which a flex tube is connected to. My question is about the copper pipe coming out of the wall. The hole around it is much bigger than the actually circumference than the pipe itself. That is because the plumber put a plug on the end while the remodel is going on. Is there any type of cover other than just mud that a person can get to be decorative and cover the hole? Thanks.
BobL43
DIY Senior Member
Long Island, NY
The easiest to install, but not necessarily the most attractive escutcheon, is the split type with a pivot that opens up and you place it around the pipe, and then close it, like the fist one on this link to Home Depot, or other sizes shown that might be needed if the copper pipe is other than 1/2 inch copper: (it got censored out) so just go to Home depots web site and search for "pipe escutcheon". It will be the first picture top left
Ingeborgdot
Kansas
Went to our hardware store today and they had them but not for my size. The pipe coming out of the wall to the toilet is a 1/2". They had for 1/2" pipe or 3/4" copper but not 1/2" copper. I live 40 miles from Home Depot, so I am not going to drive there just to get one. I guess I need to order one online but need to find one that fits my 1/2" copper. Thanks.
BobL43
DIY Senior Member
Long Island, NY
Oh well, I thought it would be easier for you with the info I gave you. Bear in mind that the actual outside diameter of 1/2 inch copper measures 5/8 inch in diameter. An escutcheon that is for 1/2 inch IPS (iron pipe size) will have an opening of 7/8 inch in diameter. Your tubing coming out of the wall is most likely the copper one, as you said. If a web site says its ofr 1/2 copper, then it should be. Why don't you order it online from HD? the shipping is probably more than the item, though.
hole
A "floor and ceiling plate", which is what those hinged escutcheons are, is one of the tackiest ways to cover the hole around a fixture water line. They are also just plain metal and will quickly rust in a damp bathroom. Do it the right way and remove the valve, then slide the proper escutcheon on, (unless you can find the split plastic ones which open and spring closed).
Ingeborgdot
Kansas
How is that tacky? I think they look a lot less tacky then they way the people had it. With a hole larger than the pipe so you can see into the wall. Where do you find the split plastic ones?
Jimbo
San Diego, CA
By all means, find a split ceiling plate. 1/2 CTS is so common, I am surprised they didn't have that size. For the orignal installer, it is tacky to not use a one-piece escutcheon, or in your case to use none at all. But you have no choice. Spit is better than the hole! No one is going to send in the escutcheon police to give you a "tacky" ticket!
BobL43
DIY Senior Member
Long Island, NY
I've used several of those metal split plates, and never had one rust on me; must have gotten a lucky good plating job on the ones I bought
Whew! hj had us worried about the tacky ticket LOL!:D
BobL43
DIY Senior Member
Long Island, NY
Inge, HJ is correct, a pro plumber would never install a split plate, but this DIYer gives you permission to if you wish.;)
