pex rings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rockycmt, Apr 8, 2011.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    I am interested in doing some pex plumbing and want to invest in a good tool. I see there are two types. Compression ring (Tool goes around the entire ring and compresses it.) and crimp ring (Tool crimps one side of the ring and compresses it.) Which is Better? I also do not want to get a tool that only works with hard to find fittings.
    Any comments?
    Chris
  2. jadnashua
    Well, actually, there is a third type that expands the tubing so you can then insert a fitting. Then, the tubing memory squeezes itself down onto the fitting by itself. Because you expand it, the fitting has less restrictions since it is larger.
  4. BenWara
    BenWara New Member
    Oct 30, 2010
    sd
    this probbly won't be to helpful but my house was plumbed withh pex and they used the crimp type. I've added a few fixtures so naturally just went with that type. The only problem I have is if you have to take the band off. they sell a tool that cuts the compression ring off so you can reuse fitting but haven't seen a tool to remove the other type. I end up just using a hacksaw to cut the crimp off which is kind of a pain sometimes. maybe i just need bigger cutting pliers? other than that the crimp type is working good for me. The tool i purchased to crimp the ring is by apollo and was less than $40.
Similar Threads: rings
Plumbing Forum, Professional & DIY Advice Lubricant that will help shower valve o-rings last longer??? Jul 21, 2015
Plumbing Forum, Professional & DIY Advice New Pex Rings Dec 24, 2014
Plumbing Forum, Professional & DIY Advice Can I use stainless rings on PB conversion coupling? Jun 2, 2014
Plumbing Forum, Professional & DIY Advice Ever a test done of wax rings vs other toilet to flange sealers? May 30, 2014
Plumbing Forum, Professional & DIY Advice Ox-Box, F1807, ProPex, and Sharkbite Crimper and Rings May 24, 2013
