Perfect Flame GSN3318N
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rbest23, Mar 31, 2009.
  1. rbest23
    rbest23 New Member
    Mar 31, 2009
    I have a GSN3318 propane grill from perfect flame. It has 4 main burners, a side burner and a back burner for the rotisserie. I want to convert this to natural gas but I am having problems getting correct orifice sizing. Perfect flame makes a natural gas version identical to what I have and when I contact the company to get replacement parts all they could tell me is the parts are out of stock. Look for direction on what drill size I need and where to get replacement orifice blanks in the event I screw up, not that I will. Thanks
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    What are you going to do about the regulator¿
  4. hj
    orifice
    You probably WILL screw up if you do not have a set of orifice drills, and they are not cheap. One way would be to use the drills to find out the LP orifice size and then use a conversion table to find the proper natural gas size for that same btu.
  5. jadnashua
    The jets are fairly common parts, but as mentioned, you MUST also change the regulator. If you know what number they are supposed to be, a good plumbing supply store and maybe the big box stores will carry them. The number of burners is not a good guide to the size of the pipe you need...you need to know how many BTU the thing can create when all are on.
  6. rbest23
    rbest23 New Member
    Mar 31, 2009
    Would any regulator for nayural gas do? I mean one used for BBQ's
  7. kingsotall
    Aug 17, 2008
    NHMaster, think we're gonna need that duct tape cranium cap...
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yea sure why not...
    It's not like anything can go wrong is it...
    [​IMG]
  9. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Everybody, I bring you the three second steak. :D
  10. kingsotall
    Aug 17, 2008
    Season's latest BBQ attire:
    [​IMG]
  11. Redwood
    Dec 15, 2007
    Service Plumber
    It's good to be thinking about PPE but as always in order to have protection the proper equipment must be selected.
    I think this would be more appropriate...
    [​IMG]
  12. jadnashua
    My last grill had a data plate on it that listed the jet size for both NG and propane. The conversion was fairly straightforward...unscrew the propane jets, screw in the NG jets, and replace the regulator, then hook up the gas line.
  13. kingsotall
    Aug 17, 2008
    Jim, that's fine and dandy but this is on a whole other tangent. Drilling out orifices, slapping on a regulator from some other unit... Remember what happened with Frankenstein¿ :p
  14. jadnashua
    Yes, propane and NG operate on two different supply pressures. Propane is a denser energy content gas, operates at a higher pressure, and therefore needs a smaller orifice in the jet. Drilling out a jet and getting the proper size is not as simple as just making the hole bigger with a common drill bit. Ensuring the hole is exactly the right size and there are no burrs, etc. is critical to proper operation. Get it wrong, either with the jet size or regulator and you can have a very dangerous situation.
    If you know the jet size required, you can find them from other suppliers than the original manufacturer (who almost certainly didn't make them themselves). Know the amount of BTU's required, and you can find a regulator that will work safely. Getting it all together in a safe operating condition takes care and attention to detail.
Similar Threads: Perfect Flame
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice New sink not perfectly aligned with drain Mar 11, 2016
Plumbing Forum, Professional & DIY Advice Dealing with imperfect surface on bottom of sink around drain hole Aug 31, 2010
Plumbing Forum, Professional & DIY Advice Perfect way to find the right plumber! Oct 14, 2008
Plumbing Forum, Professional & DIY Advice Steam Gas Boiler Flame Oct 26, 2016
