Pegasus 7000
Discussion in 'Shower & Bathtub Forum & Blog' started by jmitchum, Jun 20, 2007.
  1. jmitchum
    jmitchum New Member
    Jun 20, 2007
    I recently installed this in my new bathtub. the valve has a single handle with a knob on the tub water spout to redirect water to the shower. Here is the problem. When I turn on the cold water at first all is good. As I continue to turn the handle to the hot the pressure increases and the water starts to drip from the shower head. If I turn the water more toward the hot usually this will usually stop but not always. Is this correctable or am I going to have to replace whole thing? Any ideas would be appreciated thanks.
  2. jadnashua
    Many of these are very sensitive to how they are plumbed..what kind of pipe is used, and if the proper outlet is used. While some valves may have two outlets, one going up for the shower and another going down for the spout, some designs won't work right if you use both. Gravity often wins when water is concerned, but if there are any restrictions, the water can back up and fill the riser tube for the showerhead. You'd have to read the instructions on that particular valve to be sure, but they may have taken the plug out of the second outlet to make plumbing easier, when the manufacturer has indicated you cannot do that or you get exactly what you are seeing. It can also happen if you used pex to feed the spout, since it is smaller inside than copper, and restricts the flow. When the valve is set to warm, you are getting a good flow from both the hot and cold - the max available which is why you are seeing that. When it is only flowing from one side or the other, you have less volume available.
Similar Threads: Pegasus 7000
Shower & Bathtub Forum & Blog Pegasus Diverter stuck - how to get into it? Mar 12, 2017
Shower & Bathtub Forum & Blog Replacing cartridge for Pegasus Shower Sep 9, 2013
Shower & Bathtub Forum & Blog Mystery shower valve? Danze, Global Union, Pegasus Dec 13, 2012
Shower & Bathtub Forum & Blog How to keep Pegasus Bamboo Roman Tub handle/fixture from twisting... May 30, 2012
Shower & Bathtub Forum & Blog Pegasus Problem Dec 1, 2009
