PE Pipe Connection
Discussion in 'Irrigation / Sprinkler Forum' started by Duke76, May 6, 2009.
  1. Duke76
    Duke76 New Member
    Jul 10, 2007
    When I bought my house I had a partially installed irrigation system drawing water from a lake. The last step of the installation is to connect the pump (which is located on a floating dock) to the onshore PVC piping for the system.
    I am connecting PE pipe from the pump to the PVC using barbed fittings. The Silverline website says I can dip the end of the pipe in hot water to soften it. Does this work ? Would a hair dryer work ?
    Can someone give me any other tip on how to force the PE over the barb ?
    Thank you.
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Wait for a really hot day :)
  4. hj
    Pvc
    I assume you know that barbed fittings do not work directly into PVC.
  5. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Without a slip x barb fitting, it will be a difficult task.
  6. Duke76
    Duke76 New Member
    Jul 10, 2007
    Thanks for the comments. Let me clarify.
    The PE tubing gets a barb x threaded stainless steel fitting. I'm having trouble getting the barb inserted far enough into the PE for an acceptable fit. I need to temporarily soften the PE to get the barb inserted. The manufacturer recommends hot water but I'm trying to avoid having to carry a bucket of hot water from the house down a 200 ft hill to the worksite. That has accident written all over it!!! But that may be the best alternative.
    The PVC side gets a PVC threaded x slip adapter.
  7. hj
    heat
    A torch held far enough away and waved back and forth will heat it up, and I hope it is not a PVC male thread adapter.
  8. Duke76
    Duke76 New Member
    Jul 10, 2007
    Thanks HJ. I can't remember what PVC adapted it is and I'm not there to look. I've researched it before but can you refresh my memory. PVC female with steel male is OK but the reverse is not? Is that correct ? And is it because of expansion?
  9. Wet_Boots
    Mar 23, 2007
    Metro NYC
    There are compression fittings for polyethylene pipe, if you don't want to use barbed fittings.
  10. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    Electric heat gun works great. Hair dryer would also work just a little longer.
  11. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I've hot water, works so-so. I've used my torch, works but easy to overheat the pipe. I've use a hair dryer, works well but pretty slow. I've used a heat gun, work the best.
  12. Wet_Boots
    Mar 23, 2007
    Metro NYC
    I'd think one could pour boiling water into a small thermal water jug and haul that a few hundred feet without calamity.
  13. Duke76
    Duke76 New Member
    Jul 10, 2007
    I believe it is 1 1/4" ID.
  14. Duke76
    Duke76 New Member
    Jul 10, 2007
    Thanks to everyone for their ideas. I used a hair dryer for about 5 minutes and that did the trick.
Similar Threads: Pipe Connection
Irrigation / Sprinkler Forum Which part do I need to connect new pipe to existing pipe? Jan 29, 2017
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum Use of Pvc Drainage Pipe Sep 2, 2016
Irrigation / Sprinkler Forum What's best size of Irrigation pipe Aug 24, 2016
Irrigation / Sprinkler Forum Agriculture Irrigation Pipe Aug 22, 2016
