PCV transition
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rancher, Dec 31, 2007.
  1. Rancher
    Rancher Guest
    What is the best way to transition from PVC to either a brass gate valve i.e. male PVC to female brass, or would it be better to use a brass/gal steel nipple and go from female PVC with SS hose clamps to the male brass/gal steel.
    Rancher
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Don't think male metal into female plastic is legal in any code...
    That being said, I prefer to use half of a SCH80 PVC nipple into the female brass valve body then glue the PVC into a coupling and then to the pipe...
    The SCH80 nipples do not break as easily as the MIP fittings and other male plastic adapters I have used...
    If the connection has to be disassembled frequently you can use a union (or banded coupling if the application is not a high pressure one)...
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    NEVER use plastic FIP adapters for metal MIP.
    However, male plastic into metal is fine.
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    That makes sense, and I can also see the advantage of using half of a nipple like Mark mentioned. However, I recently discovered that some of the CPVC fittings (such as slip x thread male adapters) at the local box store are labelled "cold water only". Do you know what that is about? It looks to me like that is just some kind of ploy for selling the more-expensive plastic/brass hybrid version.
  6. hj
    cold only
    Hot water will create massive expansion/contraction issues and then the all plastic adapter will leak at the threads.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Is this PVC outside the house?
  8. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Trust me, you don't want to use those things on potable (cold also).
    The brass/CPVC are expensive, but the plastic will fail, saw it happen...not gonna happen to me.
    The threads are so mallable thats it's difficult to know when they're over-tightened/stripped.
  9. Rancher
    Rancher Guest
    Yes PVC is outside, it's the transition to the water line to the inside, which is now going to be PEX due to the copper failing. I'm going to use a brass gate valve this time due to bad experience with the plastic handles on the PVC ball valves breaking off (3' underground...).
    Rancher
  10. Rancher
    Rancher Guest
    So I guess the consensus is, Schedule 80 PVC (the Gray stuff, right?) into the brass, and cut off the other threaded end and couple to Schedule 40 PVC (the white stuff) using a coupling.
    Did i get this right?
    Rancher
  11. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Sounds good, unless you can find a brass X CPVC adapter at your local supply..brass threads are best.
Similar Threads: transition
Plumbing Forum, Professional & DIY Advice Advice for transitioning PVC to non-standard cast iron Oct 10, 2015
Plumbing Forum, Professional & DIY Advice What kind of drain pipe is this? How can I best transition to PVC? Feb 8, 2015
Plumbing Forum, Professional & DIY Advice PVC transition to Cast Iron May 31, 2014
Plumbing Forum, Professional & DIY Advice Abs-PVC Transition Cement for just Abs by mistake May 6, 2014
Plumbing Forum, Professional & DIY Advice transitioning from galvanized to copper Dec 16, 2013
