Parts needed for Duravit Wall Hung Toilet install?
kuhndog
Washington DC
Apologies in advance if these questions have already been answered in previous threads
What extra parts will I need to install the Geberit carrier in 2x6 framed wall and attach a Duravit bowl to the carrier? That is, what is not included with the carrier besides the actuator plate?
Any wisdom on the usefulness of the sound insulating gasket?
Will be using the Happy D bowl on a sheetrock wall. Other side of wall is exposed to central stairway of home, so noise suppression is a consideration.
Have read elsewhere that must depress actuator button for duration of flush. Is that defect of a particular actuator plate or the way system is designed to work?
Thanks for your help
Peanut9199
Ontario, Canada
Nothing else is needed.
I have not sold many gaskets, i do not think it is needed. It's only a thin piece of styrofoam between the wall and bowl.
The tank is insulated and very quiet, you would most likely hear a regular toilet through the wall than a in-wall carrier toilet.
You do not need to hold the actuator to flush, you only push it once.
