installing wall hung toilet with ledge above
brooklyn bk
nyc
i would like to install a wall hung toilet with a ledge above it, which will require a shorter carrier unit inside the wall. does anybody have tips on how to minimize the height of the ledge? from reading the posts, the geberit 2 x 6 seems to be the preferred carrier, but i'm open to other suggestions. thanks!
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Without incredibly costly engineered solution, a wall behind a wall hung two bolt style WC needs to be attached to the ceiling. If you are only talking about an opening, then yes, you could frame a opening if it has support to ceiling on both king studs.
brooklyn bk
nyc
thank you for sharing your expertise, Breplum.
there is an existing ledge already, similar to the ledge in these pics, attached.
