P-Trap Lower than Drain Pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rayleeis, Jan 16, 2006.
  1. rayleeis
    rayleeis New Member
    Jan 16, 2006
    SINK CLOGGED! P-trap too low for waste stub.
    Hello,
    Please take a look at the picture I've attached.
    My Sink does not drain.
    My P-Trap is lower than the waste line and I cannot connect to the stub out.
    I've put two 90 degree angle pipes to connect it to the stub. Is this a S-trap, or not. Will this work?
    Will the water "climb" up these double 90 angles pipes???
    Thanks.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    It will drain. You have created a deep p-trap, but not an s-trap. It will be sluggish. Why can't you just shorten the tailpiece dropping down from the sink, so the trap will connect normally?
  4. rayleeis
    rayleeis New Member
    Jan 16, 2006
    Because of the drain for the sink...the drain for the sink itself is like 5 inches deep...and it is threaded...so i had to buy a female threated adaptor, then attached a special pipe with a dishwasher outlet...and that is threaded as well...so i had to buy two female threated apatops and put a piece of PVC in between because i could not find a threaded coupler. Then after that piece...I put in my P trap..and by that time..I was below the waste line stub out.
    But you're telling me it should work..the water will run upwards like that?
  5. jimbo
    jimbo Plumber
    San Diego, CA
    OK, I understand you need the wye, not shown. You can accomplish that with a single fitting: it will be called a 1½" wye tailpiece. It has a flanged upper end which will connect directly to the bottom of the sink, and the lower end drops right into the trap. Overall length of this piece is probably about 8". If that sounds like it will work, go to a good plumbing supply house and spring about $ 8 for it.
Similar Threads: P-Trap Lower
Plumbing Forum, Professional & DIY Advice Lower kitchen drain to line up for new p-trap Nov 13, 2013
Plumbing Forum, Professional & DIY Advice Kitchen P-Trap Question Mar 7, 2017
Plumbing Forum, Professional & DIY Advice P-Trap Under Floor Feb 6, 2017
Plumbing Forum, Professional & DIY Advice P-Trap Weir and Vent Line Height Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Is this shower p-trap j-bend backwards? Feb 2, 2017
