Outdoor sump pump
dankoos
Columbus, Ohio
I have a vacation home that has had water around the footer. We dug down to the footer and are preparing to lay some pipe for a french drain. We also waterproofed the block and where the block meets the footer. With the footer being down about 3 feet, there is no natural slope to use to get the water out of there so we are going to use an outdoor sump pit and pump. The deepest pit I can find is 32" (and this is technically labeled as a sewage pit of some kind, but could serve the same purpose) with others being around 28" and these are more for this purpose. My question is, since the bottom of the pit has to be lower than the french drain, should I just have the surface slope toward the top of the sump so that the top is not "under ground" and so the bottom of the pit is lower than the french drain? The pit will be taking the water from the foundation as well as the downspout drains which were draining into the ground somewhere and backing up after heavy rains. So no issue with the downspout drains as they will be higher up. The water collected from the pit will be pumped to the river out back. I also have to figure out how to prevent this setup from freezing in the winter. I hate to disconnect it because here in Ohio we get some good rains in between freeze cycles. Any ideas appreciated.
Here are a few links that referenced deeper pits, and extensions for pits.
https://www.jimmurrayinc.com/fiberglass-basins-extensions
https://www.sumppumpsdirect.com/manuals/Zol_Basin_Spec.pdf
http://www.akindustries.com/products/103/24x48-inch-Ribbed-Basins
https://www.menards.com/main/plumbi...bed-basin/akp20010/p-1444423407584-c-8598.htm
Drick
Given the cost of a pre-made pit you may want to consider making your own pit using some Portland cement and building a plywood form.
dankoos
Columbus, Ohio
That's a good idea. To make it even easier, you think using one of those cardboard cylinder forms would work? Just pour the concrete on the outside instead of the inside?
Toolaholic
General Contractor Carpenter
Marin Co. Ca.
Go online for Liberty sump pump and fiberglass pits. Zoeller ,and little giant. are two more companys. Go Big ! Good luck Sully
Drick
It could work although I think you may have trouble finding one wide enough. If you make it too narrow your pump will die an early death cycling on and off too frequently.
