Outdoor Faucet Alternatives for Summer Use
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lc1983, Jun 9, 2008.
  1. lc1983
    lc1983 New Member
    Jun 9, 2008
    Since I'm installing a low pressure (25lb) micro-irrigation system outside to water hanging plants, I'm thinking that I could integrate an outdoor garden faucet into the system for summer use, about 20 feet away from the house on a wooden retaining wall (that runs between the house and garage).
    At present I have a brass manifold with 4 garden hose outlets attached to a frost resistant sill cock on the exterior of our house. I'm using two of the 4 outlets to supply the micro-irrigation system using Orbit fittings and one of the outlets for a garden hose. So that leaves one garden hose outlet open on the brass manifold.
    My question is simply whether I can use the remaining garden hose outlet to connect (with appropriate fittings) to a horizontal run of flexible 1/2" CSA rated (150lb pressure rated) polyethylene plastic pipe that in turn connects (with appropriate fittings) to a faucet mounted on the wooden retaining wall (with a drain outlet for fall use). I thought I'd run the 20' length of PE pipe about 12" horizontal above grade level and use a push-fit elbow to go up to the faucet mounted on the retaining wall. An existing concrete patio between the house and garage precludes running any underground pipe (without a whole pile of extra work).
    Helpful suggestions most appreciated, including comments on feasibility, better alternatives and best kind of fittings to use with the 150lb 1/2" polyethylene pipe. Given a northern climate, I'd drain the PE pipe each fall. Thanks in advance!
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Sounds insane to me.
    Were I to do something like this, it would be with deep-buried 200 PSI polyethylene, and a deep-bury hydrant. And I would never leave it on all night.
    And that's if I didn't already have a sprinkler system to which I can already attach any manner of micro gadgets.
Similar Threads: Outdoor Faucet
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet attached to house Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Freeze Proof Sillcock outdoor faucet Jan 3, 2017
Plumbing Forum, Professional & DIY Advice How do you find the location of the outdoor faucet from the basement? Aug 16, 2016
Plumbing Forum, Professional & DIY Advice Help Needed with Leaky Outdoor Faucet Sep 24, 2015
Plumbing Forum, Professional & DIY Advice A LOCK - Outdoor Faucet - Want The Best! Sep 3, 2015
