Outdoor 3-way switch and timer
Discussion in 'Electrical Forum discussion & Blog' started by Hillel, Nov 20, 2007.
  1. Hillel
    Hillel Member
    Sep 26, 2007
    Cleveland, OH
    Hello Everyone,
    My brother just had an electrician install an exterior flood light fixture and outlet for his patio. Apparently it needed a permit, he lives next to the vice-mayor, and not many electricians can pull a permit in our little suburb. He wanted a timer on the circuit, that will actually be used rarely, and he likes to use compact flourescent flood bulbs.
    The electrician installed a decent quality electronic timer in a box alongside a duplex switch where the top switch is a two-way and the bottom is a three way. The timer is wired for a three-way switch against the three-way switch next to it. Both the three-way switch and the timer then feed the two-way switch. The three-way switch then acts as a bypass for the timer in the circuit, and the two-way switch controls the light on and off even with the timer on.
    I should note that in testing, the bulbs run on the timer with no flicker. However, it is well known that CF bulbs with electronic ballasts and electronic timers mess with each other. The box the timer came in did not mention anything about CF or electronic ballast compatibility.
    Now, I have to ask, why such an elaborate setup? The only thing I can think of is that the 3-way bypass will prevent the CF bulbs and timer from messing up each other except when the timer is actually used. Still, why not just get a timer rated for CF bulbs with a manual bypass switch?
    ---Hillel
Similar Threads: Outdoor 3-way
Electrical Forum discussion & Blog Hot tub wiring (outdoor junction box) Sep 1, 2016
Electrical Forum discussion & Blog Outdoor Outlets - Want The Best! Sep 3, 2015
Electrical Forum discussion & Blog how to test an outdoor CF light before hanging in up Aug 6, 2015
Electrical Forum discussion & Blog Mounting outdoor outlet help needed - preference between two examples shown Aug 31, 2014
Electrical Forum discussion & Blog Transition from in-wall to outdoor EMT conduit options? Jun 19, 2014
