only warm water in shower please help!!!
Discussion in 'Shower & Bathtub Forum & Blog' started by danielspack, Sep 29, 2009.
  1. danielspack
    danielspack New Member
    Sep 29, 2009
    milwaukee wi
    ok so...
    we put in a new shower and now the water doesn't get hot, even though it's super hot in the sink that's off the same line, only four feet away?
    we replaced the valves, and cartridges, still nothing.
    then even turned off the cold water completely so that only hot could come through, and that didn't even work?
    i have no idea what to try next please help!!!!!!
  2. GoldMaple
    GoldMaple DIY Junior Member
    Jul 11, 2009
    Edmonton, Alberta
    Too Funny!
    This is Too Funny! I had the same problem on my basement bathroom project. I had to redo all the plumbing in the bathroom so I pulled it all out and then put all new piping in. The upstairs bathtub/shower lines were in this basement bathroom so I did them, too. I finished at 2 in the morning.... Did a test and all was good. Next morning my wife has a shower upstairs and says, "there's a problem in the shower. It only gets warm!" Crap! Did I cross a line? Nope, all good. WTF...... I damn near started ripping the pipe out! Part of my project was to add shut off valves to all the fixtures. So, I shut off the basement shower stall and suddenly the upstairs shower/bathtub has very hot or very cold water. I then realized that the shower rough in only has a test cap on it so the hot and cold water are mixing through the rough in!!!! Everything is cool.......just put the shower valve in. :)
  4. danielspack
    Sep 29, 2009
    milwaukee wi
    ugh
    i didn't actually add another shower though.
    just changed the old one.
    i thought it might have been something with the shut off valves but nothing gets hot even when i turn off the cold water completely?
    this is soooooo frustrating.
    thanks for the quick response!
  5. jadnashua
    New anti-scald shower valves have two things: the ability to automatically adjust if the pressure drops on one side verses the other keeping the balance approximately the same (same temp), AND an upper limit adjustment. You may need to adjust that upper limit. Depending on the model, that could be a screw, or a lever, or a clip that is generally accessable only when the trim is removed. Note, if your water temp changes radically (the cold side) between winter and summer, if you set it in winter when the incoming cold is frigid, you may get too hot of an output in the summer when the cold is (potentially much) warmer.
    Another possibility is there is some crud in the valve that is blocking flow slightly, preventing the hot from flowing freely.
Similar Threads: warm water
Shower & Bathtub Forum & Blog Lukewarm water/low pressure in shower (not the everyday problem) Nov 5, 2013
Shower & Bathtub Forum & Blog Woke up today, shower has only warm water, low pressure - all the other faucets fine Jan 31, 2011
Shower & Bathtub Forum & Blog Only lukewarm water in tub and shower Jan 4, 2010
Shower & Bathtub Forum & Blog luke warm water Jan 2, 2010
Shower & Bathtub Forum & Blog hot water luke warm in morning when heat kicks on Feb 2, 2007
