Odor coming through Sewer Vent
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tfoltz, Oct 2, 2004.
  1. tfoltz
    tfoltz Banned
    Oct 2, 2004
    Under 2 of my bathroom sinks, I have sewer odors coming out of the Sewer Vents. On the vent it says "Do Not Remove". Is this something that I can easily fix myself by purchasing the parts from Home Depot, or should I get a plumber to do the job?
    My house is 3 years old and no longer under warranty.
  2. jadnashua
    If you have what I think you have (I don't remember their name), it is used instead of a "proper" real vent through the roof. It is basically a one-way valve that is only supposed to let air in when there is a vacuum caused by water going down the drain, then close up. If it doesn't close up, it basically leaves a direct opening to the sewer. I don't think they are repairable, just replaceable.
    I'm surprised that the inspector allowed their use in new construction.
    It could be something else...
  4. Sweetfilter
    Sweetfilter New Member
    Feb 20, 2005
    Sewer Vent Odor
    Sweetfilters are carbon filled canisters that remove sewer odor from any vent stack. They easily slide onto any size pipe. For more look up sweetfilter on any search engine.
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    AAV or Studor
    i think Jim is referring to Air Admittance Valves (AAV) or Studor valves. Under your sinks.
    I find it hard to believe that two AAVs are both letting sewer gases out after three years. After you see what they look like, on the web, tell us if that is what you have.
    There may be other reasons for the odors.
    david
  6. handycat
    handycat New Member
    Oct 12, 2006
    sewer vent odor - AAV
    We're having the same ordor emitting from a sewer vent located under our kitchen sink. Geniescience, thanks for the tip on the AAV vent - yes that is what we have. Our house is 9 years old. Could this be broken already?
    Do you think this is something that we could replace, or is a plumber needed?
    Thx
  7. jadnashua
    If they left you enough pipe, then it is fairly easy...cut off the thing, glue a new one one. If there isn't enough pipe left if you cut it off, then you'll need to cut off more, and replace that section to install a new one. Once you get it off, you can cut it in half to see what it is actually doing inside.
  8. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Some of these unscrew.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    You may have what we call here a trailer vent. They are normally black or chrome color. It is similar to an AAV but notorious for failing. Go to a big box store Low*s and you can get an AAV which goes by the brand name Studor Vent. All the ones I have seen unthread.
  10. hj
    aav
    They are "throwaway" items so they always unscrew.
Similar Threads: Odor coming
Plumbing Forum, Professional & DIY Advice Odors coming from drains after plumbing remodel Nov 12, 2015
Plumbing Forum, Professional & DIY Advice How to diagnose where septic odor is coming from ? Mar 22, 2011
Plumbing Forum, Professional & DIY Advice coming home to sewer gas odor Aug 17, 2006
Plumbing Forum, Professional & DIY Advice sewer odor coming from a/c? Pls advise Aug 7, 2005
Plumbing Forum, Professional & DIY Advice Sewer odor coming from A/C ducts Sep 16, 2004
