Now it Leaks, Now it Doesn't... HELP!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MisterMagoo, Feb 21, 2009.
  1. MisterMagoo
    MisterMagoo New Member
    Feb 21, 2009
    This is a strange one but maybe someone can help figure it out:
    3 days ago my daughter turned on the shower and it immediately started raining in the kitchen below. I ran upstairs and turned off the shower but the water kept coming through the kitchen ceiling at a pretty good rate. I went to the basement and turned off the hot and cold water supplies to that bathroom. The water from the kitchen ceiling finally stopped. I was able to see water behind the shower surround and I am 99.9% sure that it wasn't a shower-curtain-water-on-the-floor problem.
    Now after 3 days I'm trying to determine what happened so I can fix it. I turn on the hot and cold valves to try to find where it is leaking and now there is NO LEAK! Shower on, shower off, bath running, flush toilet... No matter what I do, I can not make it leak!
    The valve in the shower is a Symmons Temptrol. Any one have any ideas? I am totally confused.
    Thanks for your help!
    -- MM --
    http://www.symmons.com/Customer-Service.aspx
  2. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Just ran into a similar problem in my house.... Turns out the drain line from the tub is cracked slightly at one of the fittings.... sometimes it leaks, sometimes it doesn't...
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Start opening walls or ceilings.
  5. MisterMagoo
    Feb 21, 2009
    Why open the walls if I can't even make it leak again?
    BTW, when it was leaking, ithe water was pouring out of the light fixtures in the kitched ceiling. Not just some dripping.
    Thx.
  6. hj
    leak
    Until you can duplicate the situation and make it leak, DO NOT DO ANYTHING. And until it happens and you can give us more information we cannot even advise you.
  7. DONinSTL
    DONinSTL New Member
    Apr 23, 2009
    Retired
    Mid-West, USA
    I had a similar experience when my children were young. Long story short. When the children were in the shower, they pointed the shower head in a direction that shot the water against the wall where there was a tiny little gap in the grout between two tiles. (It took me some time to figure this out.) With that much water pressure, it was amazing how much water was forced through. However, my shower was over an unfinished basement, so the water just followed the floor joists and dripped over a larger area.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Redwood slids a massive pile of chips onto leaking diverter/volume spool...:cool:
    Thinks to himself this is a lock baby!
    Conceals his glee from the others and gets ready to rake in the cash...
    A very common leak with these valves occurs where the T-30 diverter/volume lever enters the valve. It doesn't occur all the time but when the lever is in just the right position a lot of water can come out. If you are using this valve on a tub/shower replacing the TA-25A, will cure the leak. If it is a shower only you need a TA-25B. Remove the handle and escutchion then turn it on and insert the T-30 lever into place and move it to different positions watch for water to come out of the screw hole in the T-21C.
    Let me know when I can collect my bet...
    [​IMG]
    I wouldn't open anything up untill this is checked!
    This advice only applies to the Symmons Temptrol valve cited by the original poster.
  9. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Pain and consternation on the face of yours truly as Mr. Redwood manages once again to beat me to the draw. :(
    Real common S96-2 problem.
Similar Threads: Leaks Doesn't
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
Plumbing Forum, Professional & DIY Advice What causes 3 separate leaks to occur at the same time? Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Two leaks in Hardie Irrigation Valves Aug 10, 2016
Plumbing Forum, Professional & DIY Advice Sprinkler back pressure FEBCO 765-1 device leaks at vertical valve Jul 3, 2016
