1. shon
    shon New Member
    Jan 21, 2007
    I have a submersive pump on my well system. I have no water in my tank and no pressure showing on my gauge. Yesterday I shut off power to my pump,closed off the valve that feeds the house and cut the pump back on . Water then started filling the tank and my pressure started rising. I ended up with about 35psi. I turned on the valve to the house, turned on the bath faucet and lost pressure,it settled at 28psi. I got up this morning, turned on a faucet and had a trickle. I checked the tank and gauge and I have no water and no pressure on my gauge.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If you know where the pressure switch is remove the cover and try and make the switch work manually. You may just have a bad switch.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Do you mean to say you let the pump run all nite and it wasn't pumping water?
    If so, your pump may be nuked already.
    bob...
  5. Gary Slusser
    Retired
    If you have power to the pump motor and it s 'good', you have something like... a dry well, a leaking check valve in/on the pump's outlet or a serious water leak in the plumbing from the pump tha truined the pump or, a frozen water line and maybe a broken water line.
Similar Threads: water
Pumps and Tanks Well Forum & Blog. Water is life. Can/Should I install water meter in Single Family well fed system? Tuesday at 7:43 AM
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Tuesday at 6:26 AM
Pumps and Tanks Well Forum & Blog. Water is life. 4 Inch Well, Water Full of Sand, Ideas Welcome! Monday at 11:58 AM
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Sunday at 7:40 AM
Pumps and Tanks Well Forum & Blog. Water is life. Celotex as underground water line insulation? Feb 9, 2017
