No water coming into the toilet tank
Discussion in 'Toilet Forum discussions' started by jspencer, Nov 4, 2007.
  1. jspencer
    jspencer New Member
    Nov 4, 2007
    About a week ago there was a problem in the neighborhood that required the water to be shut off for about an hour. After it was turned back on, the water supply to our toilet upstairs just stopped working. I turned the valve and nothing happens. We've never had any problems with this toilet and the other bath/toilet on the same level has no issues. Any advise on how to fix this would be greatly appreciated.
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Turn off the supply at the wall...
    Unhook from under the WC and then flush the line into a bucket by turning the valve back on...
    If clear, the problem is crud in your fill valve...
    Probably just easier to replace the valve with a full replacement for about $20from your local big box store...
    Leave the supply off and remove the fill valve... Take it with you and buy a replacement by matching the valve assy to the ones in the store...
  4. jspencer
    jspencer New Member
    Nov 4, 2007
    Sure enough, the line was clogged. Thank you so much!
Similar Threads: water coming
Toilet Forum discussions Should water be coming out of Toto Drake Fill Valve? Apr 18, 2016
Toilet Forum discussions Toto Toilets - Installed with water line coming from floor vs. wall Feb 12, 2011
Toilet Forum discussions Toilet water supply coming up from floor--can Carlyle fit? Jan 24, 2010
Toilet Forum discussions Toilet Water Supply Valve Not Coming Off Dec 13, 2009
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Yesterday at 9:53 AM
