No build of pressure...
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by hammy233, May 31, 2005.
  1. hammy233
    hammy233 New Member
    May 7, 2005
    Ok....here we go again, got a call at work, my wife advising me that the line between the pump and the switch blew off and water was spraying everywhere......she reattached the line to the fitting ;) ....up until this time we have been having issues with the pump not building pressure, when it kicks in at its 30psi it runs without building pressure, I turn the switch off momentarly turn it on and voila...it begins to build pressure again....where and why is my Jet pump not building pressure, am i sucking air?..is my pressure switch faulty? :confused:
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    I would guess that there is something obstructing the ejector nozzle. Shutting the pump off reverses the pressure against the footvalve. This action may be dislodging the obstruction (at least temporarily).
    The nozzle is installed right before the impeller. When it's plugged up, the impeller doesn't get enough water, and the pump won't build pressure.
    There's nothing wrong with the pressure switch, although you should replace the line between the pump and switch. It seems like once they break, they'll continue to do so.
    For an exploded view of a shallow well jetpump go here:
    www.peekspump.com/explodesw.htm
    You'll be able to see the nozzle.
    Ron
  4. hammy233
    hammy233 New Member
    May 7, 2005
    No pressure.......
    Thanks Ron..I`ll give it a shot....try..attempt.... :eek:
  5. hammy233
    hammy233 New Member
    May 7, 2005
    no pressure........
    ok....I now know how my basement filled with water :( , the pump ran until it was so hot it, allowed the small pressure line to fall off, noticed that water was coming out between motor and pump, opened it up and found a shattered ceramic seal and a split ring on the spring, rebuilt it all, put it back together, primed it and it worked fine for 2 cycles, then back to 30psi, switch on switch off switch on switch off then it would build pressure.........the intresting thing here is when I took pump upstairs to garage I had to cut the black pipe, it basically melted to the fitting, I purchased 3ft of clear braided pvc, and made the connection for the suction end out of this, intresting to see your well water enter the pump, daughter thought it was cool :eek: but when the pump is running at 30 psi trying to build pressure..it almost sucks the hose soft/flat, once it finally grabs hold of some water it rounds out...is there a blockage in my line, is the foot valve blocked partially closed? :confused:
  6. Gary Slusser
    Retired
    I'd venture to guess yes to either or there is something sucked up against the inlet to the foot valve preventing the pump from getting water. Or.. there is a part of the drop pipe sucking closed. If it's a two line jet, then something could be blocking the jet in j-body in the well.
    Gary
    Quality Water Associates
Similar Threads: build pressure
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Outbuilding Aug 31, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Deep well builds pressure but no water output Jul 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Too long to build up pressure Jun 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Anyone build a pressure tank/pump house for -20 F? Jun 15, 2016
