bowhunter
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I have purchased a home with a shallow spring fed well, that uses a large septic tank and it has great water. The home sat empty for over 2 years, and the water system was a mess. I have just finished installing a new submerisible pump with new plumbing in the well, and have installed a new pressure tank, new pressure switch, new in line water filter and turned the system on. The pressure immediately jumps up to 30 lbs, but then it takes forever to get to 50 lbs. I have a 30/50 pressure switch. What would cause the pressure to become so slow after 30 lbs. I have checked the pressure tank, it has 26 lbs, and I have bled the system through my drain to ensure there is no air. I'm lost.
