New shower using existing shower.tub valve
mokume
Honolulu, Hawaii
Aloha all,
This post may be lengthy, I'll try to be as succinct as possible.
I've an existing shower which I plan on remodeling, as is is now the shower valve is a vintage Moen single handle tub/shower unit, plumbed off this valve is a tub spout with diverter and (2) shower heads on opposite walls, each shower head has an isolation valve inline.
Using the existing Moen valve, I'd like to add a transfer valve to either operate just one shower head or both at the same time or independently of each other, I plan on removing the isolation valves from both shower heads.
I plan on installing a non-diverter tub spout and would like to control it using the transfer valve indepently of the shower heads.
To further complicate matters, I am considering installing (1) body wash spray and have it flow with just one of the shower heads.
Water pressure @ the shower is 60 psi, fed by 1/2" copper pipe, so that should not be a problem, retaining the original Moen valve is a must.
Can anyone off insight as to what type and number of ports transfer valve I should be looking for?
TIA!
