new sand point system losing pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by trapper1, Feb 2, 2012.
  1. trapper1
    trapper1 New Member
    Feb 2, 2012
    Tipton IA 52772
    I recently attempted to upgrade my sand point well system, the old system was 12 years old and the pressure was low, but it held pressure. I put down a new sand point 3 feet away from original point, aproximate distance 15ft deep This is in a basement. I used 1 1/4 galvanized pipe with driving couplings connecting. Also new check valve and union inline close to pump. The new pump and tank and pressure switch are all in one,the tank is 5 or 10 gallon. I installed a gauge and the switch is a 30/50 switch. It took me 4 attempts to prime unit and get water. Once I had it primed the unit worked perfectly and I was really happy, I let faucets run to get clear water and any air out of system. This system is in a house I currently don't live in so the water is not ran daily. I went back to check on system and it has lost its prime, this is the second time. I even pulled the point used teflon tape and pipe dope, I really put the pressure on to get get tight fittings.I have 6 feet of water in point and pipe. There is a 1inch clear hose from pump head to "T" in tank, factor installing pipe clamps, I have tighten. Any suggestions on how to fix, I am going to buy additional pipe clamps for hose. Could new check valve be allowing system to loose pressure? Any suggests/ help would be greatly appreciated.
    Thanks
    Jay
  2. ballvalve
    Dec 28, 2009
    northfork, california
    Your foot valve may leak, and you may have suction leaks that are very hard to find. You can add another check valve at the well head to keep some water in the pump line for start up suction.
    I had a pump this week I could not prime, and I could hear air in the pump chamber. Went on a long search and found a schedule 80 union that held 80 psi under PRESSURE with no leaks, but when under suction pulled in a lot of air. Tightened the union and instant fix.
    Any way do all of your detective work on the suction end of the pump.
Similar Threads: sand point
Plumbing Forum, Professional & DIY Advice Sand point pipe broke...how to remove it? Oct 27, 2015
Plumbing Forum, Professional & DIY Advice Cant prime my well, sandpoint, pipe inside casing Please HELP Dec 9, 2014
Plumbing Forum, Professional & DIY Advice Can I use a suspended sandpoint in pond for extraction in pond 100yds away? Pump,size?sink n shower, Dec 2, 2014
Plumbing Forum, Professional & DIY Advice Sand Point Back Pressure May 28, 2013
Plumbing Forum, Professional & DIY Advice Sand Point Nov 6, 2009
